Keep your family safe and healthy with non-toxic PEVA shower liners.
The greatest danger in your bathroom could be your new vinyl shower curtain. The EPA found poly vinyl chloride (PVC) products are laden with 108 volatile organic compounds and poisonous chemicals that emit toxic gas into the air which can persist for the first 28 days. PVC plastic is softened with hormone-disrupting phthalates and includes chlorine which creates dioxin, a carcinogenic chemical formed during its creation and destruction. Dioxin is dangerous since it easily penetrates the food chain of the planet as it can travel widely without breaking down. A recent study found that in just six hours after opening a PVC shower curtain, your bathroom would be exposed to volatile organic compounds over 16 times the allowable levels for indoor air quality established by the US Green Building Council and the Washington State Indoor Air Quality Program. Bottom Line: Be wise and don't put your family at risk with poly vinyl chloride (PVC) shower curtains.
Product description
Color: Water Drop Print
Material: PEVA
Size: 72" x 72"
Item Weight: 300g
Manufacturer: Qiuyong
Item model number: QY90901SC
Water Resistant: YES
Antibacterial: YES
Mold/Mildew Resistant: YES
Ring/Hook Holes: 12pcs plastic C-type hooks
Why Choose Us
SAFE & ECO FRIENDLY - Many low quality shower liners available on the market are made from PVC, a highly carcinogenic compound that emits toxic gas into the air which can last for 28 days. Our shower liner is made with non-toxic, chlorine free, PEVA which doesn't expose your family and the environment to harmful chemical fumes.
CONVENIENT - Easily fits any standard size shower/tub and works with straight or curved shower rods. Use it as a stand alone curtain or as a liner for a cloth shower curtain. Heavy Duty magnets on the bottom prevent curtain creep keeping the water in and the cold air out.
CLEAN & GERM FREE - Our high quality anti-bacterial curtain inhibits mold and mildew growth. With basic maintenance of rinsing and wiping, be free of unhealthy and embarrassing mildew buildup and confident knowing that we offer a 12 month warranty against mildew and mold build-up.
NO HASSLE GUARANTEE - Includes a 12 MONTH WARRANTY with our 90 day "No questions asked" money back guarantee!
DURABLE - Rust proof metal grommets allow for easy sliding and pristine "new" look. Reinforced grommet header prevents tearing and insures long term use of our 100% waterproof liner.
FAQ:
1.Question: How many grommet holes does it have at the top of this shower curtain?
Answer: 12pcs plastic C-type hooks.
2.Question: What is the gram per square meter of this liner?
Answer: The GSM of this item is 90g, any other GSM can be customized.
3.Question: Do you have any other sizes?
Answer: Our regular size is 180*180cm(70.8" x 70.8"), any other size can be customized.
4.Question: Is this waterproof?
Answer: Yes, it is waterproof.
5.Question:What is the best way to clean this shower curtain?
Answer: With the temperature below 30 Celsius, hand wash or machine wash.
Note: The color is a little different due to different monitor. Please compare the detail sizes with yours before you buy and allow 1-2cm differs due to manual measurement, thanks.
PEVA Shower Curtain
website:http://www.qiuyongcommodity.com/shower- ... r-curtain/
