Iron anti rust cleaner uses advanced surfactant and solvent combination of technical solutions, both solvent-based cleaning agent efficient, while the water-based cleaning agent is not flammable and explosive, low cost of security advantages.
Technical indicators of Iron anti rust cleaner
Item Technical indicators
Appearance Light yellow transparent liquid
Operating temperature 50-55℃
Solution ratio 3-5%
Application Iron Cleaning and anti-rust
Iron anti rust cleaner is suitable for a variety of bearing cleaning, can quickly and effectively remove the bearing machine processing and use of the process attached to the oil.
1.It is 25L/drum or 200L/drum for Iron anti rust cleaner
2.We can do If you demand make a label on the package
1.We had do the export for 6 years & about 20 old clients demand Iron anti rust cleaner.
2.We can supply 500g free sample of Iron anti rust cleaner for your test.
3.Before our Iron anti rust cleaner leave factory we will do the inspection to control quality.
Metal Cleaner suppliers
website:http://www.eochemshop.com/metal-cleaner/
