Technical specification:
ModelFQ1600CFQ1800C
Max. width of paper roll1600mm1800mm
Max. base paper roll diameter1300mm1300mm
Min. width of base paper roll600mm 600mm
Min. rewinding widthNot less than 40mmNot less than 40mm
Rewinding diameter1300mm 1300mm
Max. rewinding speed140m/min 140m/min
Base paper125-600gsm depending on base paper quality
Pneumatic expanding shaft sizeAs per the inner diameters of customer’s paper cores
Power supply7.5Kw 11Kw
Dimension2370X2620X1030mm 2570X2620X1030mm
Total weight3.5tons 4tons
Function
1). Hydraulic shaft-less roll stand, paper roll loading convenient and fast.
2). Electronic hydraulic rectification, high precision.
3). Suspend type tension system, can keep the tension invariableness.
4). Heavy slitting component, higher quality in splitting.
5). Frequency conversion control synchronous belt transmission, strong power, low noise.
6). Adopt new technology, rewinding no adhesion, ensure that the distance between two paper roll is 1-2mm.
7). The aggregate-organ research-pattern Thomas rewinding, low gravity, much more convenient to unload paper roll.
8) Unloading the rewind paper rolls by air cylinder.
5. Main fittings brands
PartBrand
BearingsNSK, ABC
Pneumatic partsAirtac
Hydraulic pumpsTaiwan brand
VFDDelta
RelaysOmron
contactorsSiemens
If the high-end fq-1600c fq-1800c paper roll slitter rewinder machine caters to your requirement, welcome to buy the quality products for sale with us. We're one of the professional manufacturers in China, and we will offer you unmatched prices and service.buy automatic paper slitter rewinder
website:http://www.gzcnmachinery.com/slitter-re ... -rewinder/
